New member Username: Sandman670Chicago, IL Post Number: 1 Registered: Jun-05 | I just picked up some Norman Laboratories Model 82 speakers from a friend who had no place for them. They are 2-way, with a tweeter and a 10" woofer. The problem is the foam surround on the woofers is shot--its almost half gone on one of them. I was thinking of putting some new woofers in the same case-- 1) is this worth it? 2) where could i get reasonably priced decent woofers? 3) any idea roughly how much power these can handle? (I would consider redoing the foam, but the cones dont seem very strong) ![]() ![]() |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4160 Registered: May-04 | http://www.new-foam.com/kits.asp |
