Car radio code
Username: Dskacka
Hi,can anybody help me with radio code for my Nissan Note 2008
MMR#2CD-G BP738387802440, 7647383318
Thanks
Username: Dekster
POLAND
Post Number: 2547
DON
CODE 0549
contact me: http://koddoradia.pl/
Username: Cm_ngobeni
Hi , can someone pleas help me with my car stereo code, recently disconnected my car battery , once it was connected my stereo is asking for code , but i don't have one , info as follows:
Renault Grand scenic 2006 model
RADIO SERIAL NO:RNRD0350296532
Username: Iwos
AZERTY
Post Number: 2208
collen
FD0805160296532
8200300858TN972
Hello,
Your code is . . . . 2077
LES CODES SONT GRATUITS
THE CODES ARE FREE
LOS CODIGOS SON GRATIS
But nothing prevents a member to make a donation if he is happy with our services
Is if you would like to support the activity of the page, you can leave a quick tip via paypal.
Paypal email address : c.r.t.m.auto@gmail.com
Email Contact : c.r.t.m.auto@gmail.com
Many Thanks
Username: Dskacka
Dexter you are legend!!!!
Thanks Don
Username: Edleejay
Hi, I changed the battery on my Mercedes Benz and the radio needs a code.
I need help with my 1999 Mercedes Benz ML430 radio. The VIn is : 4JGAB72E4XA076336
Username: Titanum123
Post Number: 1446
Eddie
Username: Edleejay
CODE 53223
contact me: dekcode7@gmail.com
free codes
Username: Iwos
AZERTY
Post Number: 2228
Eddie
Username: Edleejay
R.A.S
Username: Kowie42
HI,I have the same problem as the others,the vehicle is a Renault clio,the numbers on the side of the radio are as follows RNRDAN60056476,BS0106280056476,8200607915T, SECURITY X337,I have acquired what was supposed to be the correct code, but when it was entered it went into error mode, this is totally doing my head in,can anyone please HELP, Cheers.....
Post Number: 1449
paul
Username: Kowie42
CODE 2609
free codes
Username: Kowie42
Hi again, thanks for the reply, this is the same as the code I've acquired, which does not work, any other ideas? cheers....
Post Number: 1450
paul
Username: Kowie42
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
Press And Hold " ¬ " Until A Beep Is Heard
Username: Kowie42
HI, thanks for your reply, I've tried all of the above, but to no avail,it just keeps putting error message on display,is there another way round this? Or some master code that would over ride the error message,i am living in anticipation ).
Username: Daniel27k
Hi can anyone help need a code for car radio
Ford vnr9000
Kaem015918
Username: Iwos
AZERTY
Post Number: 2233
Dan
Username: Daniel27k
Hello,
Your code is . . . . 1293
THE CODES ARE FREE
Many Thanks
