New member Username: Jason_k
Post Number: 1 Registered: May-11
Posted on Tuesday, May 03, 2011 - 02:39 GMT hello i need some help im looking to put together a full HT system, i was looking at the nad masters series setup i heard at a local dealer and loved the way it sounded i heard it on some paradigm monitor 11 speakers i thought it sounded really good. my question is, with a budget of no more than 11k for the amp, pre amp, and cd player what else should i look at in that price range if you think there is anything else i should consider? and aslo forgive me for not starting a new thread in the correct place but what other speakers should i look at with a budget of 8k for the full setup? thanks for any responses. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 16125 Registered: May-04
Posted on Tuesday, May 03, 2011 - 15:31 GMT . This area of the forum isn't highly trafficked. If you get inadequate repsonse, it's because most of the forum members aren't looking at this portion of the forum. In that case, move the thread down to "Speakers" for more feedback. . |
