Living Room
Username: Petermphelan
NJ USA
I am adding sound to my living room; it will only be used for music (no video, etc.). I am going to have 4 speakers in the room and a subwoofer ideally. I have just started addng the Sonos system to my house and I need basically a solid receiver without all of the bells and whistles of surround. The Sonos ZP120 is amplfied but I want to run both pairs of speakers at the same time, so I think it makes more sense to plug the ZP90 into the receiver. I would never turn on only one set of speakers as they would be placed in the corners of the room. Any thoughts?
Username: Stu_pitt
Stamford, Connecticut USA
Post Number: 4008
Why do you need 4 speakers running at the same time? Unless you've got a barn sized room, 2 speakers set up properly should get the job done. 2 good channels of amplification and speakers are a lot better than 4 mediocre ones.
Rather than getting the amplified Sonos, I'd get an unamplified one and connect it to a 2 channel integrated amp.
How big is your room, what do you currently have, what do you need, and how much are you looking to spend?
NJ USA
The room is about 30' x 15'. I wanted to run ceiling speakers in the four corners as I want to avoid floor speakers. I don't really have any good location for bookshelf speakers either. I could potentially do wall mounted (smaller ones) like the Bose Acoustimass but I am avoiding those if possible. My plan (as fluid as it is) was to put the speakers in and add a subwoofer for extra low-end kick. In terms of what I have, it's nothing now. I am starting basically with a blank slate. Ignoring the cost of the Sonos controller, I'd look to spend around $1000 or so on amp and speakers. A stupid question perhaps, but an integrated amp is all I'd really need (i.e. no receiver, surround, etc.)?
Username: Magfan
Post Number: 1614
In a 15x30 foot room, you can't fit in a pair of speakers? A good pair will trump 4 lesser speakers, almost every time.
NJ USA
I am being swayed by the input here towards a pair, but I am really looking for small satellite ones I can mount in the cornerrs. The area where we sit is next to a large fireplace and there are alcoves next to these which would look bad with floor speakers. I think I could mount small speakers in the corners (white) as they would blend in and perhaps that is all better than the ceiling ones. A subwoofer would still be a nice addition. The question is, which ones (not Bose) and any suggestions on a simple integrated amp (around $200)?
NJ USA
The input has been helpful. I have opted for the Definitive Tech ProMonitor 800s which I will pair with the ProSub 800. These will go on the wall and will be a huge step up from the Bose which I like aesthetically but have much better range. My final question is: I am using this with the Sonos system. I could buy the amped Sonos box and hook it up directly (it has two outputs, subwoofer output and 55W per channel). There is an unamped Sonos, though, which is $150 cheaper. Is there a decent receiver I can buy (around that $150 price difference) which would power the Definitive system better? I don't need much else in functionality as I only use it for music (no surround, etc).
Need to Register?
Forgot Password?
Enable HTML code in message
Jump to: Home Audio Forum | Home Video Forum | Home Theater Forum | Car Audio Forum
