RCA connection advice needed
Username: Dannyalasfar
Hi all, after using a set of Philips SPA 2300 I have decided that I would like to upgrade the satellite speakers.
The subwoofer has RCA output and I'm wondering if its possible to connect a pair of say main speakers, just by fitting an RCA connector to the end of the standard cable?
If this is not possible are there any alternative suggestions??
As you can tell I'm a bit of a beginner and any help would be much appreciated!
Top Deals
Loading, please wait...
Need to Register?
Forgot Password?
Enable HTML code in message
Top Deals
