Bose lifestyle model 20 cd tray stuck now will not play
Username: Dawndev
Hi i have a bose lifestyle model 20. First problem tray would not come out. that works not but then when playing cds a screaching sound would come out. Tried a cleaner disk no luck . Now no sound at all when playing cds. Track advances like all is good. All other functions work so not the speaker wires...
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 1142
Greetings Dawn,
I think if you do some research you will find that Bose mechanisms such as you CD drive fail a lot. One option is to pay to have Bose fix the drive. Another option would be to use a separate CD player and plug it into the Bose unit for amplification.
Username: Dawndev
Thanks I am waiting for an answer from Bose. They said I had to email the problem to them but no reponse yet
Need to Register?
Forgot Password?
Enable HTML code in message
