Same new guy different question
Username: Drewquan
Post Number: 11
i have just ordered my first piece of quality gear. a king rex t20 amp. my hope is to put together a good fairly cheap 2 channel audio system. i own a pair of polk audio rt800i speakers. i know their not the best but i like them hooked up to my onkyo a/v receiver. i was wondering, how would i bi amp these speakers with two king rex amps. i think the sound will greatly improved with just one king rex over the onkyo a/v. but wouldn't 2 sound better. i cant spend hundreds of dollars at one time. i think i may get the king rex psu in a couple weeks or so. and if i like everything maybe get another to bi amp later down the road.
Username: Nuck
Post Number: 10677
I didn't see if the t20 amp can be bridged, Andrew.
If like the trends tripath offerings, then it cannot be used that way.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1345
Pretty sure it can't be bridged.
However, if you look at this six moons article, you can see that the author bi-amped his rig with T20s.
http://6moons.com/audioreviews/kingrex2/u_3.html
