Changing track numbers without a pause
Username: Cescoffy
My first post - hope I can get help with this.
My first and only CD recorder so far - Philips 765 - has worked reasonably well except that I don't seem to be able to seamlessly mix my songs when recording vinyl records via my turntables & mixer, while changing the track number at the same time!
The autotrack adds a 3 second pause, while changing the track manually causes a quick hitch that ruins the CD quality.
I suppose that I could just make one long mix, but I'd have no track numbers or be able to select the songs individual without tediously searching back and forth.
I want to buy a recorder, any recorder, that will do what I want!! Being able to easily adjust input volume and set CD recording volume to avoid that up and down sound quality would also be great if possible. Naturally, cost is not a deterrent here!
Sorry to be so long-winded. Please help!
Need to Register?
Forgot Password?
Enable HTML code in message
