i just hooked up a Behringer feedback destroyer pro DSP1124P. the first day i hooked it up everything sounded fine. although the sub made a popping sound when i turned the unit on. which it does everytime i time i turn it on. is that bad?
i played around with it and the next day i turned it on and now my sub has a loud humming sound. is this a ground loop problem? can i use the feedback destroyer to remove the hum or is the unit most likely causing the hum? im going to try connecting the sub to the same surge protector as my other equipment and see if that helps.
Always turn the AVR and other electronics on FIRST! Turn on power amplifiers and sub etc last and power down with amplifiers and subs last you should hear the popping sound then because your powering up and down in the right order.
