Like
Maybe a stupid question
Username: Tongy66086
I have only recently begun playing around with burning my own CD's on my pc.
I was wonderhing how, or if, I can record the track name, etc. to the CD so it displays on my car CD player.
The stereo in the car will display info from the radio stations, and I think I've seen it do that on some of my newer CD's.
Is it possible to do this from my computers CD burner?
Thanks so much for you help.
to Bob Woods done some searching and thinks this might help u re: recording tracks and names...try this link http://www.id3.org/intro.html
Glad to help...ACEA...Ireland...Slan.
Username: Doorz
check if the compact disc logo on your car radio has got 'CD TEXT' written on top,(or if CD-Text is mentioned in the instruction manual) if yes, you can use any popular CD burning program (Nero...) to burn your Audio CD's including CD Text. If your car radio is able to playback Mp3's then you have to check that the id3 tag is correctly filled with track title, artist etc
Need to Register?
Forgot Password?
Enable HTML code in message
Facebook
Shop Related Deals
Directory
