Unregistered guest |
Posted on Wednesday, March 16, 2005 - 19:26 GMT I have a 30 year old pair of McIntosh ML-2M speakers that sound great when driven through an equalizer capable of delivering about 10db boost at very low frequencies. My old Onkyo rec'r with a tape monitor loop is dying, and I've been reading about the problems with modern rec'rs not having the tape loop. Ideally I'd like to take the L & R front channels and route them through the Equalizer which I already have, leaving the other channels straight up. But I'd need a Recvr that has a line in for audio on the independent channels. Other option would be to buy a stereo amp for just those two channels. Does anyone have a specific model suggestions, or ideas ? BobB |
J. VigneUnregistered guest |
Posted on Wednesday, March 16, 2005 - 21:34 GMT The Mac EQ can also be placed in the loop between pre amp out and main amp in. You do not, as a rule, want to EQ the line level inputs as they may overload and cause distortion.
Posted on Wednesday, March 16, 2005 - 23:18 GMT Pardon me, Mr Vigne is absolutely right, I mispoke, what I meant to say is "..I need a Rec'vr that has a main amp in for audio on the front left and right channels. " I see plenty with preamp outputs. By the way the equalizer I have used for the last 25 years is a 12 channel, + or - 12 db graphic equalizer, and the Macs have sounded great with it. |
Posted on Tuesday, May 24, 2005 - 03:20 GMT I have had a pair of Mcintosh XL1 book shelf speakers and the companion XL1W subwoofer in air conditioned storage for the last 10 years. When I hook them up they sound muffled. The cones appear to be in good shape as do the rest of the component parts. Any idea what the problem is and are they beyond repair? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 3769 Registered: May-04
Posted on Tuesday, May 24, 2005 - 04:41 GMT Are the tweeters working? |
Posted on Tuesday, May 24, 2005 - 22:28 GMT Jan - they produce sound but it is muffled. Not being very knowledgeable in this field, I an not sure what else I can tell you about their sound or performance. |
