Pioneer Help!!
Username: Hendy
I have a Pioneer XC L77 system. This runs fine for about 5 minutes, after this time the speakers create a popping type sound, then if you turn the music off you can hear this 'popping' and also what I can only describe as background 'air' type sound...any ideas to cure this would be greatly appreciated.
I have a Pioneer CDJ 500s an it show error code E 9101, anyone have any idea on how to fix this...
I have a 2 years old Headunit PIONEER DEH-P7500MP that worked just as it supposed to. Recently it started loosing power during listening CD`s. At first It started when i accelerated or drove off and on turns. So i took a close look to the wireng. I have foud out that there is nothing wrong with wires. Just the other day i have noticed that if i have the CD disc in the unit and listen to the radio the same thing happens over and over again it looses power just like i woud took the clams off the battery. And than back on ( DEMO STARTS and all the settings are lost ). So i took the CD disc out of the unit and the damn thing ( radio reciever) works without a problem. Does anyone know what could be wrong? I have disconected the sub Pioneer TS-WX20LPA too still the same thing.
Pls help me out.
This is the second Pioneer Cd-reciever that started to fail after 2 years. the first one was the DEH-5100 where the display froze or just lost the power (music still playin but no lights on display At the repair shop they sad that there is no problem with the headunit.. :unsure: :mad:
Thx in advance
Username: Edster922
Post Number: 46
Shaun: sounds like you need to replace the speakers. Have you been cranking them really loud? In some ways this is a great excuse to upgrade the speakers which usually is the crappiest part of any mini-system.
Phil: Google Pioneer tech support.
Toycar: go to the Car Audio section.
I have a Pionner 43" Plasma TV with the media box. It is hooked up to my surround sound system and does not have the Pioneer speakers attached. The media box has Input 4 AV in the front. Can someone tell me how to hook other equipment up to Input 4 and get sound through the external receiver ? I get video but no sound now. Not sure how to do it. Thanks.
Username: Edison
Glendale, CA US
Post Number: 727
mgerst - try calling a pioneer service center - they will be able to walk you through it.
Might have to adjust the input info.
i have a pioneer gm-2000 mono amp and i was just wondering if any one knows how to wire it up if you do can you please state thanks
Daz L.
We have a XV-DV77 Dvd/Cd with tuner. That for some reason every now and then locks so we cant open the tray to insert dvds or cds or then get any out! The display then flashes "Tray Lock." After loads of pushing buttons it sometimes just sorts itself out, then is fine for another year,until suddenly we are back to square one!!
Does anyone have any ideas? We would be grateful for any feedback! Thanx
I have an XV-HDT 330. When I try to play a DVD, the screen reads loading & then skips discs and shows there isn't a disc in the system. If i keep trying eventually it works. HELP!!
Track Lock?
Press and hold down the tray-button for 10 sec...
I Just need to know how to set the clock.
I have a XV-DV77 and i was wondering if it can play MPEG or Avi.
I have a XV-DV77, I am getting an error "tray lock" I can not open the tray, any advice out there on getting it to open?
HeHe i got a sx-1250 reciever weighs 65 lbs thing has no problems and its old. It has awesome sound.
Johnny Quinto
I have a Pioneer XV-DV77 DVD/CD tuner: it reads certain kinds of DVD copies and not others. It reads TDK 4x DVD-R and DVD+R copies for example, but not Memorex 16x DVD-R brand disks: it displays the message "dvd loading" for a very long time without playing the disk. Help!
Username: Vinnyg40
Carlton, Victoria Australia
hi i have a xv dv77 dvd/cd and the power goes on for about 2 seconds then shuts out
anybody know if it is common or just need a new power cord
Username: Finder23
I have a XV-DV77, I can't open the tray, I just get the error message "Tray Lock". I tried pressing and holding down the tray-button for 10 seconds, but that didn't work. Any other ideas?...
Username: Shedalee
Tray Lock XV-DV77 - Solution: press and hold the OPEN/CLOSE button for at least 10 seconds.
Username: Pflanaga
xv-dv77 volume is set to 0 and I cannot increase it. Is it likely the remote or something else. Is there a setting on the remote to put it on system mute?
Username: Twodogs
We have a xv-dv77 that made a crackle sound, and now we cannot get it to turn on. Is there a fuse or reset on these units?
Username: Nintendozombie
My Pioneer x-mf3dvd-i locked itself after I watched Toy Story3.
Whenever I try to turn it on it keeps on giving a "SYS LOCK" message. Which is pretty bitchy for a $289.99 gadget. Damn...
Username: Jithinmurali
my pioneer x mf3dvd-i locked. I try to turn it on it keeps on giving a "SYS LOCK" message
Username: Nivichan1
Hi someone help please i bought a 10 inch dual coil pioneer sub today and attached it to my Panasonic sa-akx72 stereo system not too long ago i connected the coils in parallel with the aid of a youtube video and it works but when i raise my volume beyond 26 the speaker starts making a sort of clack/clicking/poping sound can someone please help maybe i did something wrong? Its connected together with a superwoffer sub that came with the system and my system is 900 watts /9800watts well that's what it says on the box
Username: Michael_duet
i think u speakers is crack thats why they popping sound
Top Deals
Loading, please wait...
Need to Register?
Forgot Password?
Enable HTML code in message
Top Deals
