Transfer from mini dv to pc
Username: Shatsi
I have a panasonic digital palmcorder and would like to know how to transfer/download the videos on the mini dv to a pc? Want do i need to buy.
Username: Plymouth
Post Number: 16027
Welcome to eCoustics Nancy!
Is your Panasonic use a SD card?
If yes, you can buy a internal card reader for you PC.
I use this one:
http://imicro.com/item.php?item=INTANAU6MR
You put it in a 3.5" drive compartment!
Username: Ieee488
Post Number: 554
Highly doubt that the Panasonic would have a SD card.
The Panasonic camcorder should have a Firewire port. You'll need to have a Firewire port on your PC. Most PCs don't have such a port.
Otherwise, you'd need to buy a video capture card for your PC and connect up using the included miniplug to composite video+audio cable.
Username: Plymouth
Post Number: 16036
ieee488
Pamcorder use SD card:
https://panasonic.ca/english/audiovideo/camerascamcorders/camcorder/SDRH85.asp
Username: Ieee488
Post Number: 555
I know they do. The newer ones do have a SD slot.
The older mini DV ones do not.
Hers is a mini DV camcorder. Perhaps you missed that detail in her original post.
Username: Plymouth
Post Number: 16037
Without the model, it's hard to tell!
Too many time they don't list the model!
Username: Ieee488
Post Number: 556
That's true, but I know that the miniDV camcorder generation did not have SD cards. SD cards are for the newer generation of camcorders. I have a fairly "new" Panasonic miniDV camcorder. At the time I was buying it, the other choice were the ones that wrote directly to miniDVD discs and the microMV tapes.
Need to Register?
Forgot Password?
Enable HTML code in message
