Help with trasnferring edited movie back to trv33 mini dv tape
Username: Radspiffy
i have a trv33. i just transferred my movie from the tape onto my computer, and then edited it. now i want to transfer the edited version to the mini dv tape but i can't figure out how!
this is possible right??
just reply here or email me: loafofreality@Hotmail.com
Drhiberd
I don't know what program you use to edit, but I use imovie on my Mac and there is an option under the file command to export the movie. Once I select export, one of the options is "export to tape", this sends the edited movie back to the tape through the firewire connection. I would imagine that all programs would have this. See if you can find an option to export your movie, and then select "to tape". Hope this helps
