Sony dcr-hc39e (MiniDV) to PC?
Username: Thommo41
I have a Sony dcr-hc39e camcorder, and want to take the video footage onto my PC. I have a firewire cable (I-Link) to connect to my PC, but where do I go from there? Sony dont appear to provide any software? If you have a VAIO laptop, software on there allows it but its OEM software preinstalled.
Any ideas? Some software that will do the capturing for me?
Thanks in advance
Alan
Username: Project6
Post Number: 3033
Try ULEAD. Works very well.
Username: Thommo41
Hi,
Ive tried capturing, using ULead amongst others, and can only do MPEG/AVI/WMV at 640/480, and what I want is proper DVD quality, for playback on a TV.
How can I do this? As I stated in a previous post, you can do it if you own a Sony VAIO using pre-installed software, it writes direct to the DVD with no quality loss.
HELP!
TIA
Alan
Mark M
I have just bought this camcorder myself. I use Pinnacle studio and plug the firewire into the docking station. Pinnacle picks it up and has full contrul using this. Hope this helps.
