Digital Optical Cable
Username: Dodgedifferent2
Windsor, Ontario Canada
Post Number: 94
i currently have my ps2 hooked into my optical cable slot on my sony-de697. Now i just hooked up with starchoice sattelite and it also has a optical connection. I want to hook up the optical cable from satellite to my reciever, but i do not want the hassle of unplugging and plug in the optical cable when i switch. Is there an adapter for this?
Username: Eramsey
South carolina United States
Post Number: 456
Charles you need to buy an optical switcher. Check Partsexpress.com I think they are about $15-20.
Post Number: 95
i was hoping to find something in best buy, futureshop or radioshack.
Username: Eramsey
Post Number: 458
You probably can at Rat shack or Best Buy but chances are it will cost you more.
