SEAN YOUR BOX!!!
Username: Koz1031
Monticello, In United states
Post Number: 109
Sean you got a drawing on you box? If you do could I talk you into sending it to me. here's my e-mail koz1031@msn.com if you need snail mail add. let me know. Thanks I've heard (read) you talk about this a few times and it sounds like an interesting concept. Would like to take a look at it, maybe build one of my own.
Username: Insearchofbass
Post Number: 492
check your email bud sent some to you
Username: Audiobahn_man
Freakmont, MI
Post Number: 48
yea anyway you could send to me too? skateboarder_64@hotmail.com
Username: Erik123456
Arlington, Tx
Post Number: 42
whatd you come up with sean i must have missed those threads
Post Number: 508
for those who are intrested.......
you would have markings indicating your air space
amounts as you moved forward or backward
ok here it is first youll have to measure your
cars useable trunk demensions or where ever your
putting the box. what were aiming for is an adjustable airspace and adjustable port and adjustable sealed
box. I think I talked with you about this before but
ill cover the rest in case. My original goal was to
do three different adjustable boxes say 0 to 1.5 cf
then 1.5 cf to 3.0 cf then 3.0 cf to 6.0 cf. I would
build them with an inner .75 inch wall then an outter
.75 inch wall, a box in a box but the outside would
slide out creating more air space as moved out then
less as moved in. then the ports would be placed on
the box with either slot ports that are adjustable
tuned or say 4 inch pvc with different lengths which
would create different tuned amounts according to
airspace used. Then to go sealed you can create a
sealed plate to screw into the box to cover the port.
To expand usabilty you could make face plates for the
box to fit each of the three boxes one with 8 inch
woofer cut out one with 10 inch etc as far as you
wanted to go and just switch the plates according to
woofer size. The advantage gained with these boxes
would be you could tune the sub in your car using test
tone cds like my food for woofers cd and then you
could eith go by ear and test or you could do what i
did and use a spl meter and test at eith low medium or
high volumes and chart out the spl for each frequency
on paper. Then you could learn what box would be best
for your car. Maybe even someone elses if the test
boxes fit in other cars. The only other variable
would be placement in the vehicles. (some positions
may produce louder results than others) Oh and by the
way once you did the testing you could do two diferent
port arangements (one for daily driving and one for
flat out one note wonder for the spl lanes)
Post Number: 509
this is the one im using now only the box doesnt move for change in airspace its the one koz heard about
Posted on Thursday, September 09, 2004 - 01:45 am:
you could do port covers yes but i did it a different way ....i used a brace inside the box with square coutouts on the back of the box one to seal it then one to fit with a 4 inch pvc hole and made the ports to different frequencies to find the best one for my car then i could leave that one in and go sealed or ported any time all flush mounted (no air leakage either when sealed)
Arlington, Tx
Post Number: 43
wouldnt an "adjustable" not have as tight of a seal?
Post Number: 510
it would if you built it right
