Kicker solo baric
Username: Canyon2004
i plan on running 2 solo baric L5 10's or 3 L7 8's if there is not enough height for 10's. Should i run a kicker kx1200.1 or a alpine mrd m100.1
Username: Jmloughrey
Farmington, CT
Post Number: 244
go with the kicker 1200.1....much better amp IMO
ThatOneGuy04
Don't do the 8's either. I dislike those subs in general but the 10's would be better.
ya i was leaning toward the kicker amp. i should be able to run the 10's but i only have like 7 inches height under my back seat.
Farmington, CT
Post Number: 250
...where are you planing on puting these subs?
under the back seat of a 04 canyon crew cab. i will have to lift the seat 2 inches but we think they will fit. i was also thinking of AVI subs and amps.
Username: Insearchofbass
Post Number: 365
port the box so that it fires toward the walls of the truck ( where the doors are) if it has clear firing
