Need help with dyno-mat
Username: Invain
Post Number: 55
Ok, I just installed a new system in my car, and it pounds, really really loud. The only problem is that my trunk rattles so loud it sounds like it's gonna shake apart. I need to know what you guys would recommend I should use. I know there are other brands that would work just about as good as dyno-mat, and for cheaper. All I need is enough to do the inside of my trunk, and even then I might not have to do the floor. So what do I need?
Username: Insearchofbass
Post Number: 232
here you go check out the article now you can matt more than your trunk
http://www.sounddomain.com/memberpage/337124/6
Post Number: 233
let me know how it all comes out
Username: Invain
Post Number: 57
I already read that article. I would use that stuff, but I want it to look a little better. Any other suggestions?
Post Number: 235
it does look good but its your car
Post Number: 236
heres what glasswolf said in another post
fatmat
eDead
brown bread
peel-n-seal
lots of alternatives
Username: Invain
Michigan United States
Post Number: 58
thats what I needed, thans sean
Post Number: 238
your welcome and as i said before let me know your results (smiles)
Username: Pat_l
Tucson, AZ USA
Post Number: 496
www.fatmat.com
Its about 1/2 price of dynamat.
Username: Invain
Post Number: 60
how good does it work?
Username: Pat_l
Tucson, AZ USA
Post Number: 504
Just like anything else, I have never had any experiance w/ it but i have heard great things.
Post Number: 245
looks like twice the price of my suggestion but is a lil thicker i guess other than that ask these guys what you could use to make it all look good unless fatmat already looks good (assuming your reference was to the trunk lid)
Username: Invain
Post Number: 66
anybody heard much abou eDead?, you can get that pretty cheap off their site.
Post Number: 277
never did dynamating yet but my next car i will less i decide to keep my current car and give it tlc. As far as edead thats the first ive heard of it because of glasswolf. sorry i couldnt help you.
Username: Invain
Post Number: 69
I know it will probably be good if glass recommended it.
Post Number: 290
good point
