No remote wire for head unit
joel_christinson
hey what should i do, my head unit doesn't have a remote wire wire, but it does have sub outs. (already posted in headunit go no answers)
Username: Insearchofbass
Post Number: 218
remote wire and sub outs are two different things but the remote wire is usually blue with white stripe
Username: Jmloughrey
Farmington, CT
Post Number: 224
if its an aftermarket headunit it'll have a remote wire, like sean said, the wire is attached to your wiring harness, it shouldn't be used right now and its a Blue wire with a White stripe, good luck
Username: Tmf
Vicksburg, MI United State...
Post Number: 23
If your car's harness was butchered, like some that I have seen, you can simply run a wire off of the Acessory/Ignition of your car, and run a switch to it as well. That way, your amplifier will only turn on with your radio (Acessory) and if you turn your radio off, you can flip your switch to cut the current to the amplifier. You might not like the idea much, but it works out well. Good luck.
