Heard From Far...
Username: Fordtaurusbass
Iowa United States
Post Number: 17
I know I already posted a subject on this but I am still trying to decide what system I should get because I want to be heard from far away but I am also on a tight budget. I have decided that I am going to get 2 16kv.2s by elemental designs in a sealed box. What would be the best amp for these two subs and will this setup be able to be heard from far away? The subs are 650w rms. Thanks
Username: Jmloughrey
Farmington, CT
Post Number: 164
they are 650rms a peice so go with the JBL 1200.1, wire the subs down to a 2 ohm load and there you go, 600watts a sub...pretty close to perfect
