Anyone know how to wire up a system with a capactior?
Username: Chrisal202
can anyone help wire up my system i have an amp 2 subs and a capactior? Anyone care to help???
Username: Jmloughrey
Farmington, CT
Post Number: 116
...ditch the cap...
Username: Joe718
Post Number: 62
yeah man get rid of the cap better of just upgrading your alternator
Username: Jessejames
NB, PA USA
Post Number: 9
the cap just runs a power wire in one side and another wire out the the amp...
Username: Koz1031
Monticello, In United states
Post Number: 23
Is the system even hooked up yet? If not try it without the cap. You may not need it. Like joesph said you are really better off upgrading the alt.
Username: Fryguy
Barrington Passage, Nova Scotia Canada
Post Number: 58
the cap helps with the instantanous power surge the amp draws during heavy bass. Its a good idea to have it on there to help lessen the stress on the amps PWM power supply. The cap has a negative and a positive it just hooks across the power leads going into the amp.
