VW Passat/Golf MK4 Radio Code Encoding
Username: Radyocuzeko
[ENG]
Hi guys,
I need the code of this radio/multimedia (1JM 035 157DX). Related codes are as in below but please check them on images.
[TUR]
Arkadaslar 2000-2004 VW grubu Passat/Golf/Bora icin kullanilan bir teyp (1JM 035 157DX) var elimde. Bunun kodu lazim, tum acilardan forograflarini cekip koydum. Yardimci olabilecek arkadaslara simdiden tesekkurler.
Model No: CQ-JV1061XB
Serial No: 5255804
Unknown Code: *014VWZ5Z7A5255804H*
Unknown Code: VWZ5Z7A5255804
Unknown Code: M1C467010
Username: Regrooster
Post Number: 17052
VW codes cannot be calculated as they have to be obtained from the VW Dealer database so will NOT be free from anywhere on the internet.
Bulgaria
Thank you so much for your answer. I will try to decrypt the code by opening the radio and connecting the eeprom integrated inside it to the computer.
Need to Register?
Forgot Password?
Enable HTML code in message
