What type of amp should I buy for a 15 inch 6 ohm
JEFF G.
what type of amp should i buy if i want to hook up one 15 inch ma audio with dual 6 ohms, and is it better to use the 3 ohm set up or the 12 ohm.
motoman22
Get a mono amp stable to 2-ohm. Run the sub at 3-ohm.
hiphopanonymous
yea dude, get an amp that is stable down to 2, then you'll be fine with the 3 ohms.
