Question about ohms
Username: Scottbeckerle
Post Number: 12
I have 2 JL W0 10" subs that are 8ohms a piece and i have a kicker kc350.4. Now i have 2 channels taken up by components but the other 2 are free for subs so i was wondering would it be best to run them off the amp when its bridged to 175w 4 ohms or one on each channel at 2Ohm. My guess was running them bridged but just wanted to make sure. Now i know its not alot of wats but they are JL and old so i dont wanna put alot on them just want a little bass to come out lol. Let me know what you think
Username: Boopers
Lima, Ohio United states
Post Number: 54
not sure how you'd go from 8ohms to 2 ohms....
Username: Sixstar
Post Number: 26
These ARE Single voice coil subs, right?
You are going to wire them to the bridged channels. That will give you a 4 ohm load.
Wire the subs like this:
http://www.crutchfieldadvisor.com/S-Szr6cWT7FJK/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=SVC8
If you were going to wire each sub to its own channel, each channel would see an 8 ohm load.
Post Number: 13
ok thanks alot guys just wanted to make sure they would work. And yes they are Single Voice coil subs
