JBL 600.1 + ??
Paul
Ok I have the JBL 600.1 amp, but i want to figure out some subs to throw in the back of my SC300..$300 limit for the subs..any suggestions?
ruxpinj
Do you have a box, if not find some mtx 6000's for on the internet and buy a pre assembled box at a local stereo shop. If you do have a box get some mtx 8000's or some jl audio w3v2's online for cheap. Look around and you will find some cheap subs.
Try http://www.epinions.com or http://www.ebay.com
Good luck.
Alpine type r's or rockford he2's will work good too.
John A
my buddy has two infinity reference 12s running on a jbl 600.1 and it beats down pretty hard, and has great sq. highly recommend. they are 300 watts rms so they would work perfectly for that amp. they would run you about $100 apiece on crutchfield, and cheaper elsewhere.
UR a damn genious!!!! I am going to buy that Amp and the more I hear about people buying it, the better I feel.
1 12" Kicker L7, u can get for about $180, stick in a ported box. Will blow away any 2 subs sealed.
Big Fuzzy
bRETT,
1 12" l7 will blow away any 2 sealed subs???
...even my two Alpine Type R 15's?!
I doubt it and I can bet no one in your small hick town can afford two Type R 15's and an amp big enough to push them (jbl 1200.1 is what I got)
bRETT = B|TCH
