Recoil redsp???
Username: Subnoxious
I got a recoil redsp it is a blutooth 4-channel amp with a dsp built-in. Does anyone have one run one of these? The instructions are in Chinese i translated them through bixby vision but csnt find the App to controle the dsp. Can anyone help me out please?
Username: Nate0
Peoria, AZ USA
Hi. I also own one of these. I only own the Bluetooth android software. However I really want the control software for PC, but have not got my hands on it yet. The Bluetooth software works but it is not very intuitive for lack of terms. I cannot tell whether the settings I program are ever active.
Did you translate the Chinese manual completely? I could not fully translate it, but I used Microsoft translator and took photos...
Whats up nate i did alot of research on this to say the least. I ended up reverse image searhing and came up with 1 picture of this amp installed by A car audio store in Hong Kong so if your good with computers i came across something I want to try. Bet i have been able to run the recoil thru an app to connect to bluetooth from my deck to the dsp and i ran 3 amps throughthe dsp but im not anbe to control the other amps so if you want to try this is my email ghost.n.2211@gmail.com send me an email with your phone number and ill call you im in Chandler
Username: Nate0
Peoria, AZ USA
Hello @Subnoxious
Are you still around. Did you ever locate the software?
Username: Gaarg
New Dehli, Dehli
Post Number: 13
I think that you did not quite correctly translate, this often happens, since the translation from Chinese is quite difficult for a regular translator.
Need to Register?
Forgot Password?
Enable HTML code in message
