Amp not working?
Username: Frostbytes
Pierre, SD United States
So a while back I tuned my amp to produce a bit more bass and it apparently wasn't ready to take that load so I think it got fried up. Bought a new amp, its a 125A amp (Dont know brand right this second), power shows its on but it the subs won't work for some reason. I already tested the subs on another persons amp and it worked just fine so subs shouldn't be the problem. Subs are 10" Blaupunkt. Checked fuse to amp, fuse under hood, checked my wiring and all should be good still.
Need to Register?
Forgot Password?
Enable HTML code in message
