Grundig sc303 code
Username: Geoffhartwell
BURY ST. EDMUNDS, Suffolk United Kingdom
recently i bought a vauxhall calibra, found this stock unit for it but it has no code serial number is 90 464 776, any help would me much appreciated
sorry serial number is gm1303v3640994
Username: Regrooster
Post Number: 12772
Try code 6527
thanks reg, its in safe mode at the moment , so leaving it on for 2 hrs and hoping it resets, as suggested on a provisos post i found here
Post Number: 7
well it turned its self off after 1 hr
Post Number: 12776
Try leaving it switched on with the Ignition Key in Position 1
Post Number: 8
ive got it hard wired with 12v dc in my house
Post Number: 12777
As it is not in the car , have you got both 12v supplies (the permanent 12v and the Ignition Switch 12v)connected to your radio ?
Otherwise if your radio is taking longer than 1 hour to reset when switched on ( as suggested previously) then it may have to be taken into a Radio Decoding Service to be reset
Post Number: 9
no just 1 , will connect both, now
Post Number: 10
yer it hasn't worked, what sort of place would i take it to to get reset
Post Number: 12778
Does it still switch off after an hour?
Post Number: 11
yer
Post Number: 12779
Try a Google search quoting your local area .... or ask at a local Car Audio Store
Expect to pay around £20/£25 ( plus P&P both ways if mail order) ....so it might be more economical to buy a replacement radio with a working code.
Post Number: 12
think your right, put this one in the bin, thanks for your help and knowledge
