Code needed
Username: Mollyhannah
Hi sorry to trouble you, my van has come back from the garage but my stereo says it needs a code. I don’t have one. Someone told me to join here and ask you guys. Not sure if you can help me or not but it is a PU-2294A with the long code of 70000001563 thank you
Username: Rezon
Post Number: 191
Hi, try code 2131
No that didn�t work, thank you though
Username: Regrooster
Post Number: 12573
2131 is correct
Check your barcode number beginning C70000001563 again
