New member Username: DangererBangkokThailand Post Number: 1 Registered: Jul-17 | I bought from eBay. But radio area jpn I change to area euro but need code 4 digit I tried put number till CODEWAIT How can I do ? XQE 100 360 BP 9262 X 1262365 FD 249 INDEX 04 |
Gold Member Username: IwosAZERTY Post Number: 3213 Registered: Jul-14 | dangerer New member Username: Dangerer Bangkok Thailand Post Number: 1 Registered: Jul-17 Posted on Saturday, July 08, 2017 - 00:46 GMT I bought from eBay. But radio area jpn I change to area euro but need code 4 digit I tried put number till CODEWAIT How can I do ? XQE 100 360 BP 9262 X 1262365 FD 249 INDEX 04 ============================== Hello, To thank me for the help you can leave a small donation through PayPal.. PayPal e-mail address : c.r.t.m.auto@gmail.com If you have a problem with the code contact me : c.r.t.m.auto@gmail.com Your code . . . . 2292 Many Thanks ========================== Please note that this decode service will provide a four digit code that is widely used around Europe. Certain countries, including the USA were reprogrammed when they left the factory with a five digit security code. If you select the USA version from the menu when prompted, a solution will be provided for those requiring a 5 digit code. Please Note: Your USA Radio with a 5 digit code needs to be programmed using the 4 digit code provided by following the procedure below. Code Entry as Follows: Switch on ignition Switch Radio On - Display Shows " CODE - - - - - " Press and Hold ��M�� for six seconds Until display shows ��AREA + Your Country�� Press preset " 1 " repeatedly To toggle through the regions USA �" CANADA �" OC + RDS �" JAPAN - EUROPE Select ��AREA EUROPE�� Turn OFF Radio Switch Radio On - Display Shows " CODE - - - - " Enter your 4 digit code Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press RH Tuning Button " > " To Enter Radio is now on Press and Hold ��M�� for six seconds Until display shows ��AREA EUROPE�� Press preset " 1 " repeatedly To toggle through the regions USA �" CANADA �" OC + RDS �" JAPAN - EUROPE Select ��AREA + Your Country�� Turn OFF Radio Radio can now be used as normal |
New member Username: DangererBangkokThailand Post Number: 2 Registered: Jul-17 | How can I do Your passcode it's work but everytime when I turn switch off and turn on radio alway request code And when I put CD it's show CD ERROR |
New member Username: DangererBangkokThailand Post Number: 3 Registered: Jul-17 | How can I do Your passcode it's work but everytime when I turn switch off and turn on radio alway request code And when I put CD it's show CD ERROR |
Gold Member Username: IwosAZERTY Post Number: 3214 Registered: Jul-14 | dangerer New member Username: Dangerer Bangkok Thailand Post Number: 2 Registered: Jul-17 Posted on Saturday, July 08, 2017 - 09:09 GMT How can I do Your passcode it's work but everytime when I turn switch off and turn on radio alway request code And when I put CD it's show CD ERROR ======================= Check the radio's electrical connections ??? See link => https://www.dndservices.co.uk/bmw-business-cd-dnd4197.html |
