Need cobe for Ford
Username: Todordi76
Sony model: C307/C214 serial no V084174
Username: Regrooster
Post Number: 11863
FORD V SERIAL NUMBER CODES
If your radio has the Ford V Serial Number then it will not normally be available for free as access is required to the Ford factory database (unless you can blag it for free from Ford)
A recommended reliable place who will guarantee the code is here
www.ukbookshelf.co.uk/fordv
Otherwise try your Ford Dealer or a Radio Decoding Service
