Greetings. I have an old Opel Corsa B, with Philips DC347 Radio. I had the car without a battery for a while and the radio needs a code. As I understand you need the code, stamped on the side on the metal casing. Philips DC 347 model number: 22 DC 347/78 prod number: FD 09 97 24 9043025 Serial number stamped on the metal case: PH347FV9043025
Imputed the code, remote display says "Wait" I am waiting. Another question while we wait. Is this code permanent or next time something like this happens should I ask for another code? I am asking because I will write this code somewhere in the car just in case (if it works). Edit: Code didn't work. I tried it again, no luck. Right after I confirmed it there was a beep.
