Recently bought this car from a second hand dealer, its apparent theyve either swapped the radio or removed the battery as im needing a code to play CDs!
Tried a few sites and no luck, plus the renault dealer will take a day or so to do it, thought i would try this first!
Serial - RNRD6950112024 Security is - C744 FD01 0521 0112024 8200483757T
Dont really know what else is needed! Cheers for any help you can give!
