New member Username: Aboblal82Post Number: 1 Registered: Apr-15 | for ford focus radio code , serial number is WFOFXXWPDFXS41751 THANK U |
Platinum Member Username: RegroosterPost Number: 11782 Registered: Aug-08 | We cannot supply Ford Codes from VIN The correct radio SERIAL NUMBER is required for a code It usually begins with M or V followed by SIX digits ...such as M654321 or V654321 Sometimes pressing buttons 6 & 1 together or 6 & 2 will display this number Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing Radio removal instructions can be found here www.fitaudio.com/index.php?CategoryID=13 |
New member Username: WlsnrbrPost Number: 1 Registered: Apr-15 | hello there Please, i need discover the radio code for PIONER DEH-M1107ZC because i have not the code. Could you help me? PIONER DEH-M1107ZC 96 748 367 77 sn: KCPB021112CS Other informations: XFCS and 15D1 --> i do not know what this mean. thank you so much Wilson |
Silver Member Username: Decode_radioPost Number: 706 Registered: Jan-14 | Wilson New member Username: Wlsnrbr vin from car please contakt me http://forum.kody-radio.pl |
New member Username: WlsnrbrPost Number: 2 Registered: Apr-15 | Hi friend, The vin is: 8AD2MKFWXBG074350 Tks. |
Gold Member Username: DeksterPOLAND Post Number: 2163 Registered: Sep-12 | Wilson sorry we can't help Main Dealer or a Decoding Service only for this code contact me: http://koddoradia.pl/ |
New member Username: WlsnrbrPost Number: 3 Registered: Apr-15 | No problem. Thank you. |
