New member Username: Philh41West Midlands UK Post Number: 1 Registered: Jan-15 | I'm looking for the code for my ford 6000CD radio. The serial number is V178718. Any help would be very much appreciated. Thanks in advance. |
Silver Member Username: Titanum123Post Number: 910 Registered: Oct-13 | philh41 New member Username: Philh41 Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software. Otherwise try your Ford Dealer or a Radio Decoding Service |
New member Username: Philh41West Midlands UK Post Number: 2 Registered: Jan-15 | Ok, thanks for your help, hadn't realised they weren't usually available. |
New member Username: PhickeyPost Number: 1 Registered: Jan-15 | Looking for code pls lads serial number is m443018 Any help muchly appreciated.. Model is 6000ne |
Silver Member Username: IwosPost Number: 676 Registered: Jul-14 | Phickey New member Username: Phickey Hello, TRY CODE .. 7991 |
New member Username: PhickeyPost Number: 2 Registered: Jan-15 | Cheers mate that worked ur a star |
New member Username: Cruzito79Post Number: 1 Registered: Jan-15 | Hello i got a problem. I lost my code for my radio. I got a model 6000cd rds eon seriealnumber is M017755. Can somebody please help me out |
Silver Member Username: IwosPost Number: 681 Registered: Jul-14 | Cruzito79 New member Username: Cruzito79 Hello, TRY CODE .. 7378 |
New member Username: Cruzito79Post Number: 2 Registered: Jan-15 | cheers mate. Thnx for the quick reply |
New member Username: Mjohnson4488Post Number: 1 Registered: Jan-15 | Hi, Looking for the code for 6000ne Ser No. M544140 |
Silver Member Username: Decode_radioPost Number: 523 Registered: Jan-14 | Mark New member Username: Mjohnson4488 CODE 7455 contakt me http://forum.kody-radio.pl |
New member Username: Mjohnson4488Post Number: 2 Registered: Jan-15 | Wow, quick....I'm very surprised and very happy, been without music for 4 months now. Thanks |
New member Username: BabamohammedPost Number: 1 Registered: Jan-15 | hey, please am looking for the keycode for my ford focus 6000 cd changer with serial no m176262. Thanks |
Silver Member Username: IwosPost Number: 721 Registered: Jul-14 | BABA New member Username: Babamohammed try code .. 6112 |
