Recupere code radio
Username: Rada_antoniohotmailcom
Bonjour tout le monde .. Aurait besoin de réactiver la radio est un 22Rc200 / 35 Citroen Xara. CLO402x0089582 HL214. Merci d'avance
Hola necesito ayuda.se me ha bloqueado la radio, es un modelo 22rc200/35 de Citroen Xara n�CLO402X0089582 HL214 si fuera posible GRCIAS
Username: Dekster
POLAND
Post Number: 1958
pintar1
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
contact me: http://koddoradia.pl/
