New member Username: RibeiropaPost Number: 10 Registered: Aug-10 | Hi, is it possible to obtain the code for a Clarion PU-9358A? The only additional info I have is the Serial Number: 0052322 Thanks in advance! |
Gold Member Username: OpelopPost Number: 2209 Registered: Sep-12 | Paulo Ribeiro New member Username: Ribeiropa Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 1390 Registered: Sep-12 | Paulo Ribeiro New member Username: Ribeiropa Your order jumpers contact me: http://koddoradia.pl/ |
New member Username: Decode_radioPost Number: 3 Registered: Jan-14 | Paulo Ribeiro New member Username: Ribeiropa Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. |
Silver Member Username: Titanum123Post Number: 170 Registered: Oct-13 | Paulo Ribeiro New member Username: Ribeiropa Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + +++ + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. |
Bronze Member Username: RibeiropaPost Number: 11 Registered: Aug-10 | The other bar code serial number is unreadable Bad luck, then... The battery was disconnected and now we don't have the code |
Bronze Member Username: RibeiropaPost Number: 12 Registered: Aug-10 | The other bar code serial number is unreadable Bad luck, then... The battery was disconnected and now we don't have the code |
Silver Member Username: Titanum123Post Number: 171 Registered: Oct-13 | Paulo Ribeiro Bronze Member Username: Ribeiropa code JUMPERS |
New member Username: Eam73Post Number: 1 Registered: Jan-14 | +C6 1102C52322* Hello; This is the remaining code under the bar code; I manage to recover it; doesn't look to much helpfull anyway; Thank you Emilio |
Gold Member Username: DeksterPOLAND Post Number: 1396 Registered: Sep-12 | Emilio Marinho New member Username: Eam73 Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet contact me: http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 2214 Registered: Sep-12 | Emilio Marinho New member Username: Eam73 we need number start on c7 contakt me http://forum.kody-radio.pl |
Gold Member Username: OpelopPost Number: 2215 Registered: Sep-12 | delete | |
Platinum Member Username: RegroosterPost Number: 11661 Registered: Aug-08 | Clarion PU-9358A? As already stated, this radio code is set up inside the radio using solder tag jumpers http://codedradio.info/?i=bn&st=pu-9358 See PM message for further suggestions |
New member Username: Eam73Post Number: 2 Registered: Jan-14 | thank you very much; regards EM |
New member Username: MigtiPost Number: 2 Registered: Dec-13 | Hi, i need to read the eeprom of this radio PU-2294A©, but i need to know ¿where is it? and the eeprom reference. Thanks!!! |
Gold Member Username: DeksterPOLAND Post Number: 1424 Registered: Sep-12 | migti New member Username: Migti
New member Username: EkkuPost Number: 1 Registered: Feb-14 | Help Me ! Radio code is lost. My car is Citroen Xsara . Radio model Clarion PU-2294B serial number is C6CBT0032619 / C70000004233 Thanks :-) |
Silver Member Username: Titanum123Post Number: 320 Registered: Oct-13 | dj.ekku New member Username: Ekku try code 5461 |
