Code radio alfa 156
Username: Doog
Bonjour, je cherche le code de l'autoradio de mon alfa 156
bp nr: 7640378316
prod nr fiat: 156028922
merci
Username: Titanum123
Post Number: 106
lebourg
Username: Doog
Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casing
Username: Doog
hi qwerty
i find an another code. There are 12 nombers:
bp 037812403618
Post Number: 108
lebourg
Username: Doog
try code 4223
Username: Doog
you are superman.
Thanks a lot
