New member Username: PeeleuuhWielsbeke, Belgiƫ Post Number: 1 Registered: Aug-13 | Hi, I i'm searching all over the internet to find a code for my renault scenic radio (2001) Model no: 22DC279/62P Pre-code: T0Q594 Serial no: RN279F10214741 Hopefully you can help me? Thanks in advance! |
Gold Member Username: OpelopPost Number: 1609 Registered: Sep-12 | peeleuuh New member Username: Peeleuuh Wielsbeke, Belgi� CODE 9431 contakt me http://forum.kody-radio.pl |
New member Username: Andy1985Post Number: 1 Registered: Aug-13 | Hello, could you provide a code for this please? RNRD0340204595 FD0604390204595 8200300858TT331 Thank you. |
Gold Member Username: OpelopPost Number: 1656 Registered: Sep-12 | Andy New member Username: Andy1985 CODE 6686 contakt me http://forum.kody-radio.pl |
New member Username: ShauntukPost Number: 1 Registered: Aug-13 | Hi, battery went flat on 07 Grand Scenic, and the what I thought was the code isn't being accepted. Would be really grateful for code for: Model No: RENRDW346-19 RNRDAG80137085 BS0508160137085 8200562686T Q197 |
Bronze Member Username: Masterskay62MelitopolUkraine Post Number: 55 Registered: May-13 | shauntuk New member Username: Shauntuk code 9860 |
New member Username: ShauntukPost Number: 2 Registered: Aug-13 | Thanks for the prompt response masterskay62. It's greatly appreciated. |
New member Username: Roadrunner08Post Number: 1 Registered: Aug-13 | Just changed my battrey on renault scenic 2005 now my radio is asking for the code, which i dont have Can any one help in what i need to provide for you to possibley get my code thanks |
Bronze Member Username: Masterskay62MelitopolUkraine Post Number: 59 Registered: May-13 | roadrunner New member Username: Roadrunner08 Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. |
New member Username: ChupitosPost Number: 1 Registered: Aug-13 | hola cambie bateria y ahora no funciona la radio pide code y no me lo se necesito ayuda os lo agradeceria muchisimo es un renault scenic rx4 del a�o 1999 al 2003 fase1 n� identificacio VF1JAA50E27770242 GRACIAS |
Gold Member Username: OpelopPost Number: 1729 Registered: Sep-12 | serial numbers from radio pleease contakt me http://forum.kody-radio.pl |
New member Username: ChupitosPost Number: 2 Registered: Aug-13 | gracias dorado pero donde estan esos numeros por que yo no he desmontado nada y no se gracias |
New member Username: ChupitosPost Number: 3 Registered: Aug-13 | que tengo que acer para ver los numeros de serie de la radio gracias |
New member Username: Mbmegane320Post Number: 1 Registered: Aug-13 | Hi ! missing code Renault megane -04 Model22DC277/62 RN277F30259223 TOY169 |
Gold Member Username: OpelopPost Number: 1730 Registered: Sep-12 | CODE 1807 contakt me http://forum.kody-radio.pl |
Platinum Member Username: RegroosterPost Number: 11601 Registered: Aug-08 | #chupita Please post in ENGLISH Use Google translate http://translate.google.com/ The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Removal Info here www.fitaudio.com Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing. This information can then be used to see if a code can be calculated |
New member Username: ChupitosPost Number: 4 Registered: Aug-13 | buenas quiero agradecer a todos la informacion ya encontre el codigo y esta funcionando muchas gracias estoy muy agradecido mucha salud y felicidad para todos. |
New member Username: SoffiaPost Number: 2 Registered: Apr-13 | Renault megane 2004 MODEL NO: 22DC277/62 RN277F40495122 PROD NO: FD0504170495122 8200256141TQ245 Thank you |
Gold Member Username: OpelopPost Number: 1734 Registered: Sep-12 | Mladen New member Username: Soffia CODE 9794 contakt me http://forum.kody-radio.pl |
New member Username: BeltonbikerPost Number: 1 Registered: Aug-13 | Renault megane scenic 2002 Model No: 22DC278/62P RN278F20051590 Prod No: FD0002140051590 8200152346TM242 |
Gold Member Username: OpelopPost Number: 1736 Registered: Sep-12 | Beltonbiker New member Username: Beltonbiker CODE 1584 contakt me http://forum.kody-radio.pl |
New member Username: Srp506Post Number: 1 Registered: Aug-13 | Hi Could you help me finding the radio code for my Renault Scenic 2001 Model-nr:22DC279/62P Prod-nr:FDO301280279277 7700434425TG585 |
Gold Member Username: OpelopPost Number: 1753 Registered: Sep-12 | Beol New member Username: Srp506 CODE 6405 contakt me http://forum.kody-radio.pl |
New member Username: JonathanavtsPost Number: 1 Registered: Sep-13 | Modelo 22dc278/62p toy120 rn278f00002283 prod hc0004410002283 |
Gold Member Username: OpelopPost Number: 1764 Registered: Sep-12 | jonathan New member Username: Jonathanavts CODE 1872 contakt me http://forum.kody-radio.pl |
New member Username: JonathanavtsPost Number: 2 Registered: Sep-13 | Modelo 22dc278/62p toy120 rn278f00002283 prod hc0004410002283 |
New member Username: MoklePost Number: 1 Registered: Sep-13 | Hello, i have a grand voyager 1996 se lux with a locked radio. I was wondering if you could help me with a code? The serial is TQ1AA335535739. Really appreciate your help :D |
Gold Member Username: OpelopPost Number: 1769 Registered: Sep-12 | Marcus New member Username: Mokle CODE 4434 or 2434 contakt me http://forum.kody-radio.pl |
New member Username: TimnoPost Number: 1 Registered: Sep-13 | Help took fuse out and have no code. 2005 Renault scenic Fd0805140172385 Rnrd0450172385 Renrdw132-10 Security r963 8200300859tr963 |
Gold Member Username: DeksterPOLAND Post Number: 1176 Registered: Sep-12 | Gumbo New member Username: Timno CODE 8049 contact me: http://koddoradia.pl/ |
New member Username: KimouPost Number: 1 Registered: Sep-13 | hi Renault Scenic radio code needed. Model No: RENRDW 131-10 RENRD 0350316986Prod No: FD 0905230316986 8200300858 TJ 046 Thank you. |
Gold Member Username: OpelopPost Number: 1781 Registered: Sep-12 | kimo New member Username: Kimou CODE 7925 contakt me http://forum.kody-radio.pl |
New member Username: KimouPost Number: 2 Registered: Sep-13 | but the numbers up to 1 up to 6 |
Gold Member Username: DeksterPOLAND Post Number: 1182 Registered: Sep-12 | kimo New member Username: Kimou Code Entry as Follows: Radios with Steering Wheel Control Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " for 10 seconds or until a beep is heard Radios without Steering Wheel Control: Entered using the Preset Buttons on the radio Press Preset Button 1 repeatedly for the first number Press Preset Button 2 repeatedly for the second number Press Preset Button 3 repeatedly for the third number Press Preset Button 4 repeatedly for the fourth number Press and hold Preset Button6 for 10 seconds to store code, note, some radio models use Preset Button 5 to store the code contact me: http://koddoradia.pl/ |
New member Username: KimouPost Number: 3 Registered: Sep-13 | think you |
New member Username: Djole1987Post Number: 1 Registered: Sep-13 | help me please. 8200152346tw999 thanks |
Gold Member Username: OpelopPost Number: 1782 Registered: Sep-12 | djole1987 New member Username: Djole1987 CODE 3069 contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 1184 Registered: Sep-12 | djole1987 New member Username: Djole1987 CODE 3069 contact me: http://koddoradia.pl/ |
New member Username: MorganPost Number: 1 Registered: Sep-13 | hello help me please. Model No. 22DC594 / 62F Prod No. FD0096 383 015 014 9902 215 94623 77 00 413 538 --A |
Gold Member Username: OpelopPost Number: 1789 Registered: Sep-12 | morgan New member Username: Morgan CODE 8559 contakt me http://forum.kody-radio.pl |
New member Username: MorganPost Number: 2 Registered: Sep-13 | Hello, Thanks a lot for sending the code but I just have a problem. It seems that I tried to enter several wrong codes before you send to me the code and now the radio screen in the car is hanging on âCODEâ and I canât inter the code because I must have the â0000â screen Do you have any opinion how to solve this problem |
Gold Member Username: OpelopPost Number: 1791 Registered: Sep-12 | Radios with Steering Wheel Control Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " for 10 seconds or until a beep is heard Radios without Steering Wheel Control: Entered using the Preset Buttons on the radio Press Preset Button 1 repeatedly for the first number Press Preset Button 2 repeatedly for the second number Press Preset Button 3 repeatedly for the third number Press Preset Button 4 repeatedly for the fourth number Press and hold Preset Button6 for 10 seconds to store code, note, some radio models use Preset Button 5 to store the code contakt me http://forum.kody-radio.pl |
New member Username: MorganPost Number: 3 Registered: Sep-13 | Hello, The screen is hanging on "CODE" and do not go to the "0000" screen mode atall Then I do not have " 0000 " |
New member Username: WychypooPost Number: 1 Registered: Sep-13 | Hi, I've had a new timing belt, valves and cylinder head replaced on my Renault Scenic and the garage must have disconnected the battery and now my radio just says 'code'. Details from Radio are: Model 22DC258/62P TOQ582 RN258F20016331 Prod No. FD0002070016332 8200152345TQ582 Please can someone help me |
Gold Member Username: DeksterPOLAND Post Number: 1193 Registered: Sep-12 | Lisa New member Username: Wychypoo CODE 9492 contact me: http://koddoradia.pl/ |
New member Username: WychypooPost Number: 2 Registered: Sep-13 | Thanks Dekster, the code worked. Like Morgan's post, ours was stuck on 'code' as we had tried putting a code in already. My hubby took the fuse out and it reset it so we got the 0000. Thanks again |
Gold Member Username: OpelopPost Number: 1795 Registered: Sep-12 | Lisa New member Username: Wychypoo turn on radio and wait one hour contakt me http://forum.kody-radio.pl |
New member Username: MorganPost Number: 4 Registered: Sep-13 | hello I left the radio turned on since yesterday and it steel the same problem hanging on CODE I locked through the web and i find that you can hold on AS button then tern on the radio and keep hold on the AS button till the radio reseated to have 0000 I tried that but unfortunately nothing happen I steel have the CODE I will got made |
New member Username: MorganPost Number: 5 Registered: Sep-13 | hello I left the radio turned on since yesterday and it steel the same problem hanging on CODE I locked through the web and i find that you can hold on AS button then tern on the radio and keep hold on the AS button till the radio reseated to have 0000 I tried that but unfortunately nothing happen I steel have the CODE I will got mad |
New member Username: MorganPost Number: 6 Registered: Sep-13 | Hello, What I done now, that I replaced the electric board of my radio with other one from a defected radio but the board is good. And now it is working but asking for the code Please can you help me with that? The new data is so close to the privies one Model No. 22DC594 / 62F Prod No. FD00297083051513 9902 215 94623 77 00 413 538 â"B SN. RN594 FV30 51513 I tried the code 8559 only once thinking it will work but it didnât work |
New member Username: MorganPost Number: 7 Registered: Sep-13 | Hello, What I done now, that I replaced the electric board of my radio with other one from a defected radio but the board is good. And now it is working and asking for the code giving "0000" Please can you help me with that? The new data is so close to the privies one Model No. 22DC594 / 62F Prod No. FD00297083051513 9902 215 94623 77 00 413 538 --B SN. RN594 FV30 51513 I tried the code 8559 only once thinking it will work but it didnât work |
Gold Member Username: DeksterPOLAND Post Number: 1199 Registered: Sep-12 | morgan New member Username: Morgan CODE 7651 contact me: http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1811 Registered: Sep-12 | morgan New member Username: Morgan CODE 7651 contakt me http://forum.kody-radio.pl |
New member Username: Muki71carPost Number: 1 Registered: Sep-13 | Hi may anyone help I need radio code for my Renault model no 22DC258/62P TOM213 RN258F20046361 PROD No FD0102200046361 thanks |
Gold Member Username: DeksterPOLAND Post Number: 1204 Registered: Sep-12 | muki71car New member Username: Muki71car CODE 1554 contact me: http://koddoradia.pl/ |
New member Username: K9nadavPost Number: 1 Registered: Sep-13 | please help, in the garage the mechanic disconnected the battery and ever since i try to find the code, those are my Scenic 2005 details : |
Gold Member Username: OpelopPost Number: 1822 Registered: Sep-12 | Keinan Nadav New member Username: K9nadav serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: FabsBrighton, England United Kingdom Post Number: 1 Registered: Sep-13 | hi there, I need some help getting the code for my Renault Scenic. I have bought it with out it so I would be please if you could help me out with this. MEGANE SCENIC FIDJI 16V AUTO Registration date: 24-02-2003 veichle identification Number: VF1JA0B0228097174 |
Gold Member Username: OpelopPost Number: 1843 Registered: Sep-12 | fabs New member Username: Fabs serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: SoffiaPost Number: 5 Registered: Apr-13 | MODEL NO: 22DC277/62 RN277F40643957 PROD NO: FD0704360643957 8200256141TW335 thanks! |
Gold Member Username: OpelopPost Number: 1850 Registered: Sep-12 | Mladen New member Username: Soffia CODE 3660 contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 1223 Registered: Sep-12 | Mladen New member Username: Soffia opelop Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM Single free code request for personal use only (one code request every 6 months minimum) This is for security reasons in order to prevent abuse by traders+dealers, car radio thieves and other chancers contact me: http://koddoradia.pl/ |
New member Username: Bob2008Post Number: 5 Registered: May-11 | Hello need some help with my radio codes and thanks for helping us. Renault Prod No: FDO507400288526. RNRDBE70288526. 8200607918T-Y970 Security. |
Gold Member Username: OpelopPost Number: 1890 Registered: Sep-12 | Bob New member Username: Bob2008 CODE 1033 contakt me http://forum.kody-radio.pl |
New member Username: Gillian2013Post Number: 1 Registered: Oct-13 | Hello need some help with my radio codes and thanks for helping us. Renault Prod No: FD0002160061523. RN278F20061523 8200152346TI196 Security. |
Gold Member Username: OpelopPost Number: 1897 Registered: Sep-12 | Gillain2013 New member Username: Gillian2013 CODE 1693 contakt me http://forum.kody-radio.pl |
New member Username: Gillian2013Post Number: 2 Registered: Oct-13 | thanks you very much |
New member Username: Bob2008Post Number: 6 Registered: May-11 | Thanks a bunch and God bless, it worked just great. |
New member Username: JepsterishPost Number: 1 Registered: Oct-13 | Hi! Got a 2004 Scenic, and can't find the correct code. The securitycode is: U820 And Model nr: RENRDW131-10 Please help, I reall need my music :-) Jeen |
Gold Member Username: OpelopPost Number: 1899 Registered: Sep-12 | Jeen New member Username: Jepsterish CODE 5169 contakt me http://forum.kody-radio.pl |
New member Username: Abdalla_sherazyPost Number: 1 Registered: Oct-13 | Need Philips Radiosat 6010 code !! Model: 22DC461/62L S.N:77004330720473 FD 1099214200347 code Gravage: 4200347 any help plz |
Gold Member Username: DeksterPOLAND Post Number: 1242 Registered: Sep-12 | Abdalla Sherazy New member Username: Abdalla_sherazy CODE 1591 or 9607 contact me: http://koddoradia.pl/ |
New member Username: Abdalla_sherazyPost Number: 2 Registered: Oct-13 | thanks a lot about your care but i have a problem here the radio is already stuck on the word " CODE " & i can't try any of the codes you wrote |
New member Username: Abdalla_sherazyPost Number: 3 Registered: Oct-13 | it's done! by 1591 & i enjoying my radio thank you very much you are great |
New member Username: Luke_mPost Number: 1 Registered: Oct-13 | Hiya guys, could someone help me with the code for my 05 Scenic please, numbers as follows: Model No: RENRDW131-10 RNRD0340240679 Prod No: FD0704480240679 8200300858TU014 Security: U014 Many thanks! |
Gold Member Username: DeksterPOLAND Post Number: 1259 Registered: Sep-12 | Luke UK New member Username: Luke_m CODE 5989 contact me: http://koddoradia.pl/ |
Gold Member Username: OpelopPost Number: 1937 Registered: Sep-12 | Luke UK New member Username: Luke_m CODE 5989 contakt me http://forum.kody-radio.pl |
New member Username: TyreemPost Number: 1 Registered: Oct-13 | Hi, can anyone help me? I've just bought a renault grand scenic 05 plate.. It's asking for a code when I put the radio on. Where do I get the code from? Thanks |
Platinum Member Username: RegroosterPost Number: 11620 Registered: Aug-08 | #Lis..RENAULT CODE The radio has to be removed from the dashboard Then quote the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes Radio removal instructions can be found here http://www.fitaudio.com/index.php?CategoryID=10 |
New member Username: TyreemPost Number: 2 Registered: Oct-13 | This is all the numbers from the label Security-W369 RNRD0550100259 Model no./RENRDW133-10 Prod no. FD0705060100259 8200300860TW369 8200300860--B |
Gold Member Username: OpelopPost Number: 1946 Registered: Sep-12 | Lis New member Username: Tyreem CODE 3644 contakt me http://forum.kody-radio.pl |
New member Username: TyreemPost Number: 3 Registered: Oct-13 | Fantastic it worked, thank you |
New member Username: Jush22Post Number: 1 Registered: Oct-13 | Hello I'm looking for stereo code for my renault scenic after a battery change. RN259F10324861 FD0501450324861 T0T016 7700434424 Many thanks |
Platinum Member Username: RegroosterPost Number: 11622 Registered: Aug-08 | #jush Try code 6924 |
New member Username: Jush22Post Number: 2 Registered: Oct-13 | Hi didn't work |
Gold Member Username: DeksterPOLAND Post Number: 1269 Registered: Sep-12 | Jush New member Username: Jush22 is the correct code for the Serial Number TOT016 contact me: http://koddoradia.pl/ |
New member Username: Jush22Post Number: 3 Registered: Oct-13 | Any other solution for the radio code please.. |
Gold Member Username: DeksterPOLAND Post Number: 1278 Registered: Sep-12 | Jush New member Username: Jush22 Code Entry as Follows: Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter Code Entry as Follows: Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard contact me: http://koddoradia.pl/ |
New member Username: Jush22Post Number: 4 Registered: Oct-13 | Thanks so much it's worked. |
New member Username: BigteePost Number: 1 Registered: Oct-13 | I need code for scenic 03 model no: 22dc278/62r RN278f30045899. Prod no: fd0303150045899 |
Gold Member Username: OpelopPost Number: 2003 Registered: Sep-12 | Tyrone New member Username: Bigtee Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123 contakt me http://forum.kody-radio.pl |
New member Username: BigteePost Number: 2 Registered: Oct-13 | 8200150484tl642 |
Gold Member Username: OpelopPost Number: 2004 Registered: Sep-12 | Tyrone New member Username: Bigtee CODE 2760 or 0169 contakt me http://forum.kody-radio.pl |
New member Username: BigteePost Number: 3 Registered: Oct-13 | Thanks a lot 2760 worked much apriciated |
New member Username: Nickblack423Post Number: 1 Registered: Nov-13 | Hello hopefully you nwill be able to help me with a code for my Scenic II. Model No is RENRDW132-10 RNRD0440063502 PROD NO: FD0204110063502 Thank you in advance |
Gold Member Username: OpelopPost Number: 2041 Registered: Sep-12 | Nick New member Username: Nickblack423 Please, letters/numbers from the main bar code 8200xxxxtt123, 7200xxxxxtt123 or security code, as Q123 or T0U123 contakt me http://forum.kody-radio.pl |
New member Username: Nickblack423Post Number: 2 Registered: Nov-13 | Sorry, 8200300859TD033 |
Gold Member Username: OpelopPost Number: 2042 Registered: Sep-12 | Nick New member Username: Nickblack423 CODE 1914 contakt me http://forum.kody-radio.pl |
New member Username: Nickblack423Post Number: 3 Registered: Nov-13 | Legend thank you very much that worked like a treat. |
New member Username: MattrussellwbaPost Number: 3 Registered: Nov-13 | Rnrd8460030963 Renrdw232-70 Fd0206030030963 Security w791 Thank you in advance 06 scenic |
