Code number?
Username: Borderman1
LEIGH, LANCASHIRE United kingdom
Hi,
could anyone please help me find the correct code for my radio which is a CLARION model no PU-2294B(D)
serial no CL042Z0510137 as the one on the unit starts
22?? would be ever so grateful as silence isn't golden in my car................thanks john.
Username: Dekster
POLAND
Post Number: 1028
john d s
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
contact me
http://koddoradia.pl/
