Peugeot 306 car radio code needed
Username: Bobibobi
Hi to all i need an urgent help please!!! i need a code for car radio in my peugeot 306 type 2.0 HDI radio has been blocked for over a month due to a battery failure here is a
Model No:22RD200/65
Product No:FDO199269018083
THX IN ADVANCE!
Username: Bobibobi
Model No:22RC200/65
THX IN ADVANCE! ooops..sorry guys its 22RC200/65 with
FDO199269018083
Username: Regrooster
Post Number: 11471
The correct radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing.
This information can then be used to see if a code can be calculated
Username: Willys_wheels
i've lost my radio code, please help
s/n m023659
2005 mondeo
Username: Dekster
POLAND
Post Number: 376
willzi
Your code is : 9830
contact me:
http://koddoradia.pl/
e-mail: stefan15@poczta.onet.pl
I greet.
thanks Dekster, you're a gem
Username: Kira
Hi,
I lost my radio code. I had to chage my car battery too....
Please help me!
Clarion PU-2294A
CL04014050375
Thanks
Post Number: 11496
Kira Frost
Username: Kira
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
Username: Kira
ok...
i found
C70000006431
C6CBV0503750
Username: Dekster
POLAND
Post Number: 396
Kira Frost
Username: Kira
try code 1665
contact me:
I greet.
Username: Geomoldova
hello there.
need code for my renault cabasse radio.
serial number : 8200205833T C945
thank you very much.
Post Number: 11502
Geo
try code 2781
Reg Rooster, thanks.
Username: Bobibobi
Hi i lost my radio code and still i cant find it...guess i was providing not enough information as i was informed so:
the radio is philips(cassete player)made in france car model is peugeot 306 model No:22rc200/65
product number is:FDO199269018083
next number is :TOF680
and it has another number:029018
guess this will provide u enough information to find the code
thx thx thx in advance hope ull help me!!!}
Post Number: 11503
bobibobi
Username: Bobibobi
try code 3525
