Alfa romeo 147
Username: Hamo751
Hello, I bought in second-hand garage Alfa Romeo 147, but I have no code for the radio, we did not give it to me, help me please thank you.
500189443144490
735387753
68G113T2H B01
Username: Regrooster
Post Number: 11487
The correct radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing.
This information can then be used to see if a code can be calculated
