I need a radio for my renault megane 2003
Username: Emmaalex691
Hi - can anyone help? my alarm kept going off in the night so I disconnected the battery and now it is asking for a code for my radio, this is the custom fitted radio and the information I have is as follows:
Model 22DC277162
TOP431
RN277F20043839
Prod No FD0002440043839
Barcode 8200256141TP431
Username: Dekster
POLAND
Post Number: 180
Code is: 0559
contact me:
e-mail: stefan15@poczta.onet.pl
I greet.
I tried this as it was in my book but i put the code in and nothing happened, do i have to do anything else once I have entered the numbers??? many thansk
Username: Regrooster
Post Number: 11369
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don't have the [¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [¬] button then rotate the thumb wheel for the correct first digit
Press the [¬] button then rotate the thumb wheel for the correct second digit
Press the [¬] button then rotate the thumb wheel for the correct third digit
Press the [¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed
Press the Second Preset Button repeatedly for the 2nd digit to be displayed
Press the Third Preset Button repeatedly for 3rd digit to be displayed
Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code )
Post Number: 11370
see above
