CLIO CODE
Username: Max65
i cant get code for my clio ...help ?
model no 22DC279/62F
PROD NO FD0300380076228
TOR240
RN279FY0076228
8200029541TR240
hope thats enough info
Username: Regrooster
Post Number: 10828
try code 8748
Username: Max65
brilliant thanks
Username: Timpuri
Hi,
Just had an used radio for Clio from the used parts yard.
But I don't have code for it. Can you help with it?
In the label text is:
Model No: 22DC278/62B
TOT507
RN278F30398990
Prod No: FD0403090398990
Thanks
Post Number: 10860
Username: Timpuri
try code 6441
Username: Timpuri
Thanks for the answer. I'll test it tomorrow.
Username: Timpuri
Got the radio in place. The Code worked like a dream. Thanks!
Username: Michaelkinahan
Hi I have made the mistake of disconnecting my battery! I have a Clio 1.4 dynamique 16v!
Model 22DC278/62B
Sec O243
RN278F40732354
Prod No FD0704060732354
Reg No WK042ZWN
Many thanks in advance
Michael
Username: Bogege
BG
Post Number: 468
Michaelkinahan
if O243-code-1759
if Q243-code-9753
Many thanks works a treat!
Username: Tasha1994
I took my car radio out to put another radio in and now i want it out to put my old one in and i dont know the code as i didnt get when i brought the car
PROD: FD 1099069115113
MODEL NO: 22DC481/62
RN481FX9115113
hope this is enough. thanks.
Post Number: 10954
Username: Tasha1994
try code 9110
Username: Tasha1994
THANKYOOOOUUUUUUU WOOOHOOOO IT WORKS CHEEERS :D
Username: Laza05
PROD.FD0506040039855
MODEL NO.RENRDD200-00
RNRD2160039855
BAR COD 820035419T
UNAPRED HVALA
Post Number: 10963
Username: Laza05
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Coyote981
DWY492
MODEL NO: CLIO 2001 RT 1.9 DIESEL
Nro F8QK630C550631
Post Number: 10975
Username: Coyote981
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Username: Candido
boa tarde alguem pode me mandar o codigo de desbloqueio do radio clio
mod: 22DC279/62F
prod: HC0101050020530
renault:8200029541TQ226
8200 029 541 - -
Sse puderem ajudar agradeço desde ja
Username: Elektron1234
Poland
Post Number: 395
candido
code is 9761
contact me:
e-mail-stanislawgoclon@o2.pl
Username: G0n3
model no 22DC461/62Е
PROD NO FD 11 99 36 2327799
7700 433 074 0505
Username: G0n3
sorry about the previous post the model number is model no 22DC461/62E
Post Number: 10993
Username: G0n3
Username: G0n3
i have no idea what's these codes are but i write if you need them
9022 21461622
this is under the barcode 7700 433 074 0505
under the text RQ i have this number 3111 186 94130
RN461FX2327799
m/ch 328509
hope that's enough info
Username: Pauldurham3
hi ive just got a second hand renault stereo but no code can u help please
MODEL NO 22dc279/62f
PROD NO FD0300400083689
BARCODE 8200029541TI481
RN279FY0083689
T0I481
0200 029 541
Post Number: 11027
Try code 0755
Post Number: 11028
New member lanko
Username: G0n3
Sorry ...not in my database
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Neurologic
Plegase.
MODEL NO:22DC278/62H
TOR5649
RN278F20010479
PROD NO :FD020260010479
agradezco infinitamente tu atencion y apoyo.
Post Number: 11060
TOR5649
Check this number again as it has too many digits
please...
RNRD6950082685
RENRDW240-00
FD01 0517 0082685
Username: Flapsa
Can anybody help me? tanks!
Model no: 22dc278/62b
T0Q294
RN278F10040717
Prod no: FD0101280040717
Barcode: 820057681TQ294
Post Number: 11079
Username: Flapsa
try code 9799
Post Number: 11080
TOR5649
Username: Flapsa
Thanks reg rooster i tryed the code, but i doesn't work. THE radio makes à biep and sayes code fore à while. Then after à while you can try again. Do you no what i need to do?
Post Number: 11085
Flapsa
Username: Flapsa
Apologies...the code should be 9729
Username: Flapsa
Thanks man! Its works again!
