Bonjour Suite à un changement de batterie, mon autoradio me demande le code et je ne l'ai pas ! On m'a conseillé de venir vers vous, je vous donne ma rèf : BMW BUSINESS RDS 65.12 - 8 379 230 PH7850X1434174 KW 09/99 INDEX: 00
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
