Primastar code
Username: Wheeliewizz
Worthing, West Sussex
Hi guys, fuse blown and wiped out the radio......and no security code in my documents.
Nissan can't
help and hoping [and grateful] someone here can,
Model No 22DC279/62
Serial No RN279F50509710
Thank you in anticipation
Username: Iwos
Post Number: 348
Glen
Hi,
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Thanks for the response Amaida.
Found 'T129SECURITY'
Thanks
Username: Iwos
Post Number: 350
Glen
try code .. 6804
Wow, your a star. Really grateful for your time solving the issue Almaida. Many, many thanks.
Glen
