Gold Member Username: RegroosterPost Number: 9857 Registered: Aug-08 | 2412 is the correct code Blaupunkt 7644495091 - Renault Code Entry Instructions Turn on the radio, the display will show 'CODE' . Press any pre-set key and the display will show '0000' Press Preset Button [ 1 ] repeatedly for the first digit Press Preset Button [ 2 ] repeatedly for the second digit Press Preset Button [ 3 ] repeatedly for the third digit Press Preset Button [ 4 ] repeatedly for the fourth digit Finally press the Preset Button[ 6 ] to enter the code. The set will display 'CODE' briefly and switch on. |
New member Username: DomovfevPost Number: 1 Registered: Feb-12 | could you get me the code please 22dc259/62p tot111 rn259f10320953 fd0501440320953 029021 7700434424tt111 |
Gold Member Username: RegroosterPost Number: 9881 Registered: Aug-08 | Domovfev ----------------------- try code 6841 |
New member Username: DomovfevPost Number: 2 Registered: Feb-12 | worked perfectly thanks |
New member Username: CaezonPost Number: 1 Registered: Feb-12 | Hi, need some help, I have a 2004 scenic, need the code please! 22dc278/62r t0j154 RN278F20016014 Prod No: FD0202300016014 8200150474tj154 8200 150 474 |
Silver Member Username: Elektron1234Poland Post Number: 114 Registered: Jan-12 | caezon code is 7751 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: Sousou74Post Number: 1 Registered: Feb-12 | Hi Guys Help !! We bought a Renault Scenic 2005 but it did not come with the radio code - here are the details: - Model No.: RENRDW131-10 - RNRD0340159338 - PROD No.: FD0404240159338 - 8200300858TK501 thanks a million |
New member Username: Peterjaniga28Post Number: 1 Registered: Feb-12 | Hi, need some help with my code. I have got a Scenic 2000. Could you help me please? 22DC461/62P RN461FX8036955 Prod no: FD1199378036955 Model no:22DC461/62P 7700433943R388 |
New member Username: LittlemisssunshinePost Number: 1 Registered: Feb-12 | Hi , I'm hoping you can help , i have a renault scenic 2000 model no: 22dc279/62p prod no: FD0100110057924 TOU988 RN229FY0057924 I've got pics of codes and lots of other numbers ie bar code etc plus numbers which have been stamped into the metal should u need them. Many Thanks |
New member Username: Majaco10Post Number: 1 Registered: Feb-12 | Hi, unfortunately I too have had to have a new battery and now can't use my radio (the code in the paperwork doesn't work) I have a 2007 Renault Scenic RNRDAG70021244 RENRDW346-19 BS0207110021244 8200562686t - V779-SECURITY (8200 562 686 -- B) i would be very grateful if someone can help me out thank you |
New member Username: Majaco10Post Number: 2 Registered: Feb-12 | thank you |
Silver Member Username: BogegeBG Post Number: 401 Registered: Dec-10 | Sousou74 try 4924 |
Silver Member Username: BogegeBG Post Number: 402 Registered: Dec-10 | Peterjaniga28 try code 8672 |
Silver Member Username: BogegeBG Post Number: 403 Registered: Dec-10 | Littlemisssunshine try code 5097 |
Silver Member Username: BogegeBG Post Number: 404 Registered: Dec-10 | Majaco10 try 4227 |
New member Username: Stockport70Post Number: 2 Registered: Feb-12 | hi , i think i might have posted my stuff in wrong part of the forum,just come accross the scenic part when still looking for a code,its driving me insane! the details are radio sat 6010 7700 433072 philips 22DC461/62L 9022 214 61624 FD 09 98 43 4070210 22DC461/62L FD 0998434070210 RN 461 FY4070210 (Y MAYBE X AS IS OVER A HOLE?) thanks for any help you might have. ian |
New member Username: AkadzijaPost Number: 1 Registered: Mar-12 | model no: 22DC25B / 62p Prod No: FD0203250114614 T0C239 RN258F30114614 8200152345TC239 Thanx |
Silver Member Username: Elektron1234Poland Post Number: 132 Registered: Jan-12 | Miroslav code is 1772 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: DcuPost Number: 1 Registered: Mar-12 | Hi, I'd be grateful if someone could give me the code for my blaupunkt car 300 D in my Astra. Battery died a couple of weeks ago. serial #: GM0300T5451365 model: 7 645 852 520 Other number: 90532620 Thanks in advance dave |
Gold Member Username: RegroosterPost Number: 9966 Registered: Aug-08 | dco CAR300 ========================== Try code 5399 |
New member Username: Lelek_2Post Number: 3 Registered: Dec-10 | Hi. I'm customer of Renault Scenic '99; 1.6 benz. and i forgot code for radio from this car. Please help. This radio is: Philips 22DC459/62L; 9022 214 56924 Prod. No:FD 0898304221803; 77004264120979. Thnx for any help. |
Gold Member Username: RegroosterPost Number: 9980 Registered: Aug-08 | Leszek RENAULT ================================ Sorry.......this is insufficient information The radio has to be removed from the dashboard Then quote the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
New member Username: Lelek_2Post Number: 4 Registered: Dec-10 | Reg Rooster: with this picture i hope you try found solution (code). Thanx for ansewr. OK. I think i found code. For this radio probably the code is: 1069. |
Gold Member Username: RegroosterPost Number: 9987 Registered: Aug-08 | Leszek RENAULT ======================================== Yes ..1069 |
New member Username: Giovanni2Post Number: 1 Registered: Mar-12 | Hi, just bought a scenic with a beeper radio could I please ask you for a code? TOC 762 Rn259f10324149 Bar code: 7700434424tc762 Thank you |
Silver Member Username: Elektron1234Poland Post Number: 158 Registered: Jan-12 | Giovanni code is 1632 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: Giovanni2Post Number: 2 Registered: Mar-12 | Thank you so much Elektron...email on it's way. |
New member Username: ShalomPost Number: 1 Registered: Mar-12 | Hello I have Scenic from 2004 and lost the Radio code, it's TUNER list model Model no: RENRDW132-10 RNRD0440125349 PRPD no: FD0704440125349 V100 Security 8200300859TV100 8200 300 859 -B Thank you in advance. |
Silver Member Username: Elektron1234Poland Post Number: 159 Registered: Jan-12 | Ricardo code is 4877 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: ShalomPost Number: 2 Registered: Mar-12 | Thanks, it worked |
New member Username: LittlemisssunshinePost Number: 2 Registered: Feb-12 | Thank you Thank you Thank you |
New member Username: Chick2Post Number: 2 Registered: Mar-12 | I've recently bought a 2002 (52 plate) Renault Scenic and would like to find the Radio Code. Radio numbers as follows - Model no - 22DC258/62P RN258F20024725 8200152345TU952 Any help appreciated. |
New member Username: ArdiianPost Number: 1 Registered: Mar-08 | i need a code please renault clio 1.4 2000 RN279FY0020078 8200029542TW324 |
New member Username: EyelashPost Number: 1 Registered: Mar-12 | Any help with code for renault megane scenic please? RN278F20017349 8200150474TQ157 |
Platinum Member Username: RegroosterPost Number: 10040 Registered: Aug-08 | Roryboy RENAULT ============================= Duplicate post....Already answered Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion |
Platinum Member Username: RegroosterPost Number: 10041 Registered: Aug-08 | Eyelash RENAULT ============================= Try code 9862 |
Platinum Member Username: RegroosterPost Number: 10042 Registered: Aug-08 | aristocrat RENAULT ==================================== Try code 3692 |
New member Username: Richy137Post Number: 1 Registered: Mar-12 | Hi, need radio code for my 53 plate scenic. Product no: FD0103360050331 Model no: RENRDW131-10 Theres also this code: TOU274 RNRD0330050331 |
New member Username: Richy137Post Number: 2 Registered: Mar-12 | I need the code for my radio in my scenic. The model no is RENRDW131-10 Product no is FD0103360050331. Also has codes: TOU274 RNRD0330050331 Many thanks in advance |
New member Username: Richy137Post Number: 3 Registered: Mar-12 | Sorry for posting twice. Didnt think it had worked first time. |
Silver Member Username: Elektron1234Poland Post Number: 172 Registered: Jan-12 | Richard Sydenham code is 5723 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: Stockport70Post Number: 3 Registered: Feb-12 | hi,posted on march 1st , had no reply either way, is there a code available or shall i just buy a new radio? thanks ian |
Platinum Member Username: RegroosterPost Number: 10073 Registered: Aug-08 | stockport70 New member Username: Stockport70 Post Number: 2 Registered: Feb-12 Stockport70 posted on Thursday, March 01, 2012 - 12:15 GMT hi , i think i might have posted my stuff in wrong part of the forum,just come accross the scenic part when still looking for a code,its driving me insane! the details are radio sat 6010 7700 433072 philips 22DC461/62L 9022 214 61624 FD 09 98 43 4070210 22DC461/62L FD 0998434070210 RN 461 FY4070210 (Y MAYBE X AS IS OVER A HOLE?) ========================================== Is there also a SECURITY NUMBER? . This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If not try emailing restoredclassic@aol.com to see if they can help Mentio this forum |
New member Username: Stockport70Post Number: 4 Registered: Feb-12 | hi - thanks for reply, it could be K063 ? theres a label with the barcode 7700 433 072 K063 on the casing? |
New member Username: GizmobladePost Number: 1 Registered: Mar-12 | Please help with code model number: 22DC279/62P TOG188 RN279FY0153948 Prod number: FD0300430153948 i hope its all the numbers you need. |
Platinum Member Username: RegroosterPost Number: 10076 Registered: Aug-08 | stockport70 RENAULT ---------------------------------------- Try code 5914 |
Platinum Member Username: RegroosterPost Number: 10077 Registered: Aug-08 | Jimmie/Gizmoblade RENAULT ========================== Try code 1534 |
New member Username: Stockport70Post Number: 5 Registered: Feb-12 | thanks a million Reg Rooster. that worked great. now the codes marker penned on top of the radio. thanks again. ian |
New member Username: Fred334Post Number: 1 Registered: Mar-12 | Hi I have recently had some work done on my car and in doing so the radio was disconnected , unfortunately the code supplied does not work. I would be most gratefull if someone could help me . Thank you in advance , the information I think required is as follows. Rnrd0430045171 Security. N112 8200300859tn112 barcode Fd0203530045171 production number Renrdw132-10 model number |
Silver Member Username: Elektron1234Poland Post Number: 174 Registered: Jan-12 | Fred code is 2810 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: FttPost Number: 1 Registered: Mar-12 | Hello, please help with the code for Grand Scenic: The model no is RENRDW131-10 Product no is FD0805110281305 Also has codes: 8200300858TZ755 RNRD0350281305 Thank you. |
Silver Member Username: Elektron1234Poland Post Number: 175 Registered: Jan-12 | FTT code is 0248 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: BluedaisyPost Number: 1 Registered: Mar-12 | Hi, the AA had to disconnect my battery to be able to push the car onto their recovery pickup - would be really grateful if you could you tell me the code for my radio (I bought it 2nd hand so dont have a record), here's the info: model no RENRDW121-10 P887 SECURITY RNRD0340192181 PROD NO: FD0604360192181 BAR CODE: 029021 0192181 8200300858TP887 Many thanks x |
Platinum Member Username: RegroosterPost Number: 10086 Registered: Aug-08 | bluedaisy RENAULT ========================== Try code 0151 |
New member Username: Westy74Post Number: 1 Registered: Mar-12 | hi could you help me pls garage diconnected battery code needs entering for a 2005 grand scenic model no.renrdw132-10 prod no.. fd0905200188413 barcode.8200300859tk594 k594 security rnrd0450188423 MANY THANX in advance |
Platinum Member Username: RegroosterPost Number: 10104 Registered: Aug-08 | westy RENAULT ==================== try code 4939 |
New member Username: EltercoPost Number: 1 Registered: Mar-12 | Hi, i replaced the battery from my renault Scenic 2006, I dont have the code for the radio car. can you help me? Thanks in advance This is the information i can provide you: Model code: JA1V145 Serial Number: JO96923 Engine Number: K4mj706q089323 VIN; 93YJA1V257J775927 |
Silver Member Username: Elektron1234Poland Post Number: 187 Registered: Jan-12 | Martin code is 4829 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: Westy74Post Number: 2 Registered: Mar-12 | thank you regrooster ever so much |
New member Username: NmnpPost Number: 1 Registered: Mar-12 | Hi, usual story, battery disconnected, no code. Please help Model No 22DC259/62P Prod No FD0400450187336 Barcode 7700434424TP112 thanks |
Platinum Member Username: RegroosterPost Number: 10125 Registered: Aug-08 | Neil RENAULT ============================ Try code 0814 |
New member Username: NmnpPost Number: 2 Registered: Mar-12 | Thank you Reg Rooster, you are a star. |
New member Username: TheseamannPost Number: 1 Registered: Apr-12 | Hello to everyone Could you help me finding the radio code for my Renault Scenic 2004 Model No: RENRDW132-10 RNRD0440050822 Prod No: FD0204040050822 Additional Barcode: 8200300859TS517 Thanks a million in advance! |
New member Username: TheseamannPost Number: 2 Registered: Apr-12 | Hello to everyone Could you help me finding the radio code for my Renault Scenic 2004 Model No: RENRDW132-10 RNRD0440050822 Prod No: FD0204040050822 Additional Barcode: 8200300859TS517 Thanks a million in advance! |
New member Username: WeettoniPost Number: 1 Registered: Apr-12 | Hello to all and to you Reg Rooster, Can you please give me the right code for my Renault Scenic 2008? Model No: RENRDW330-15 RNRDBE80114288 Prod No: FD0908140114288 Additional Barcode: 8200633637 --B 8200633637T M367 - SECURITY Thank you a lot m8! |
Platinum Member Username: RegroosterPost Number: 10136 Registered: Aug-08 | Weetoni RENAULT ========================== Try code 1303 |
Platinum Member Username: RegroosterPost Number: 10137 Registered: Aug-08 | The Seamann RENAULT ============================== Try code 7441 |
New member Username: WeettoniPost Number: 2 Registered: Apr-12 | Thank you Reg Rooster, it worked. First day of songs are dedicated to you m8. |
New member Username: PampPost Number: 1 Registered: Apr-12 | Hi, could someone Please help, i've found so many codes but they are all wrong and have to wait hours to enter another really fed up now if enter another wrong one might have to smash the system, so PLEASE HELP! |
New member Username: PampPost Number: 2 Registered: Apr-12 | OH! its a renault scenic grand dynamique 2005. THANK YOU! |
Platinum Member Username: RegroosterPost Number: 10152 Registered: Aug-08 | Pam-P Try code 0035 |
New member Username: KolePost Number: 3 Registered: Apr-12 | Hi Reg Rooster, i recently had my battery replaced but have lost my radio code. MODEL NO: 22DC279/62Z RN279F10138951 PROD NO: FD0101350138951 8200002607TY300 please could you help me. thanks in advance Deana |
Platinum Member Username: RegroosterPost Number: 10156 Registered: Aug-08 | kole New member Username: Kole Post Number: 3 Registered: Apr-12 Kole posted on Saturday, April 07, 2012 - 08:35 GMT Hi Reg Rooster, i recently had my battery replaced but have lost my radio code. MODEL NO: 22DC279/62Z RN279F10138951 PROD NO: FD0101350138951 8200002607TY300 please could you help me. thanks in advance =================================== Multiple post....IGNORED Please do NOT post the SAME request in more than ONE thread It is not necessary....and can cause confusion |
New member Username: KolePost Number: 5 Registered: Apr-12 | I am sorry |
New member Username: LaggylaggyKenton, Devon United Kingdom Post Number: 1 Registered: Apr-12 | Hi I have just managed to lock myself out of my scenic radio, please may I have a code, thank you in advance Model - RENRDW131-10 TN724 RNRD030076043 Prod No FD0203450076043 8200300858TN724 8200300858 Many thanks Tim |
Platinum Member Username: RegroosterPost Number: 10169 Registered: Aug-08 | Tim RENAULT ====================== Try code 2272 |
New member Username: James_wilmotPost Number: 1 Registered: Apr-12 | Hi can you help. I need the code for Scenic car radio, here are the details; Model no RENREW131 10 J867 RNRD0340101067 PROD no FD02040101067 200300858TJ867 |
New member Username: Pepa_22_locohotmailcomPost Number: 1 Registered: Apr-12 | hola como les va soy nuevo y es un gusto empezar a compartir compras y preguntas tengo una senic el cual me quede sin bateria y no tengo el manual, original nesesito el codigo del stereo paso unos dato para ver si me pueden ayudar RENRDW202-00 RENAULT 8200467807T TIENE UNA BANDA DE SEGURIDAD QUE SE DESCRIBE S082-SECURITY |
Silver Member Username: Elektron1234Poland Post Number: 196 Registered: Jan-12 | Pepa_22_locohotmailcom code is 7943 contact me: e-mail-stanislawgoclon@o2.pl |
Platinum Member Username: RegroosterPost Number: 10184 Registered: Aug-08 | James RENAULT ========================= Try code 6355 |
New member Username: SparckusPost Number: 1 Registered: Apr-12 | Hi there, our battery in our grand scenic went flat recently and we need a code. Thanks in advance. |
New member Username: Lamby2981Post Number: 1 Registered: Apr-12 | Hi, Could} you please help me i need the radio code for following Serial:-RN259F10284637 Barcode:-700434424TE904 Thanks in advance |
Silver Member Username: Elektron1234Poland Post Number: 201 Registered: Jan-12 | steven code is 1417 contact me: e-mail-stanislawgoclon@o2.pl |
New member Username: LimrenPost Number: 1 Registered: Apr-12 | Hi! because of my 2006 Lagunas navigation calculator were stolen and now i have a new one, the stereo asks code. I took pictures of the only stickers i found on the radio, hope that you can help me to get the code.. |
New member Username: VirtualsPost Number: 1 Registered: Apr-12 | Hi I have just managed to lock myself out of my scenic radio, please may I have a code, thank you in advance Model - RENRDW330-10 RNRDBE80806566 Prod No FD0908160806566 8200607918T |
New member Username: KilmorePost Number: 1 Registered: Apr-12 | Hi guys, Can you please help me with this. Had to replace battery and it is now looking for the radio code which I do not have. Its a renault scenic 2004. Here are the details SERIAL NUMBER: RNRD0340158264 SECURITY NUMBER:8200300858TT958 Thanks a lot |
Platinum Member Username: RegroosterPost Number: 10196 Registered: Aug-08 | virtuals New member Username: Virtuals Post Number: 1 Registered: Apr-12 Virtuals posted on Thursday, April 12, 2012 - 19:42 GMT Hi I have just managed to lock myself out of my scenic radio, please may I have a code, thank you in advance Model - RENRDW330-10 RNRDBE80806566 Prod No FD0908160806566 8200607918T ======================================== Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes |
Platinum Member Username: RegroosterPost Number: 10197 Registered: Aug-08 | se/kilmore RENAULT ======================== Try code 6099 |
Platinum Member Username: RegroosterPost Number: 10198 Registered: Aug-08 | Renee Limbach New member Username: Limren Post Number: 1 Registered: Apr-12 Limren posted on Wednesday, April 11, 2012 - 20:19 GMT Hi! because of my 2006 Lagunas navigation calculator were stolen and now i have a new one, the stereo asks code. I took pictures of the only stickers i found on the radio, hope that you can help me to get the code.. ========================= Have you tried 6767 or 6998 |
New member Username: LimrenPost Number: 2 Registered: Apr-12 | Yes I have tried both, error.. |
New member Username: Hawk7Post Number: 2 Registered: Feb-12 | Can somebody help me for VW gamma radio from passat b5.5 serial: VWZ3Z3A7669715 thanks |
New member Username: Fadi4474Post Number: 1 Registered: Apr-12 | Hi. I'm desperatly trying to get my radio code for my 2007 Honda Accord V6 NAVI.I have one that was supplied by the dealership - 22636, however it does not work. Not sure why. MODEL # 39051-SDA-L510-M1 REF # RG836A0 SERIAL # gnz 2203032042 Thanking you in advance for your assistance. My email address is |
Platinum Member Username: RegroosterPost Number: 10215 Registered: Aug-08 | fadifadi HONDA ================================= will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet |
Platinum Member Username: RegroosterPost Number: 10216 Registered: Aug-08 | Hawk7 VW =============================== will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet |
New member Username: Fadi4474Post Number: 9 Registered: Apr-12 | Reg Rooster ================================= Can you guide me because I do not know what to do And I thank you very much for your interest |
Platinum Member Username: RegroosterPost Number: 10218 Registered: Aug-08 | HONDA will only be available from the Main Dealer or the unit will have to be taken into a Radio Decoding Service to obtain this code It will not be available for free or cheap from anywhere on the Internet |
New member Username: KilmorePost Number: 2 Registered: Apr-12 | Thanks very much. Just tried the code and it worked. Regards Se |
Bronze Member Username: AymantnPost Number: 22 Registered: Dec-09 | car stereo code |
New member Username: VirtualsPost Number: 2 Registered: Apr-12 | Model - RENRDW330-10 RNRDBE80806566 Prod No FD0908160806566 8200607918T Security - U012 |
New member Username: WidowmakerEngland Post Number: 1 Registered: Apr-12 | Hi i am in need of my radio code after battery died radio no longer works it just asks for code that i do not have. If anyone can help it would be of great help. Renault megane scenic Philips Radiosat 6000 Philips 22D459/62F FD 05 98 02 3015037 PROD : FD 0598023015037 code : 7700 426 412 U779 |
