Code for car radio
Username: Carrjo
Vermont South, Victoria Australia
The car radio do not work after changing a new battery. It require the input of a security code.
Entering the security code, provided when the car was purchased, as per instructions in the manual did not work and causing a code error.
Any help to resolve the matter will be much appreciated.
Car Type: Holden Astra
VIN W0L0TGF4815013798
Radio Blaupunkt 520
Original Security provided 4864
Username: Fredia
America
Post Number: 18
Ohoh, you can go to the repair shop to have a check.
Username: Regrooster
Post Number: 10153
John / Carrjo
HOLDEN
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Username: Carrjo
Hi Regrooster,
It took me a while to remove the radio from the dashboard but i finally did it.
Here are the details on the radio:
On top of metal casing:
GM Blaupunkt
No :92 057 951
Type: Blaupunkt 520
U!E
BP8391Y3017861 (on top of barcode)
ASTRA
On side of metal casing:
BP8391Y3017861
Thanks
Post Number: 10187
John
HOLDEN
Try code 2888
Username: Carrjo
Hi Reg Rooster,
Thanks for the code.
Will try it when allowed (radio is still in the "SAFE": mode) and let you know the result.
