Peugeot 306 radio code
Username: Dparkinson19
I have a clarion pu-9990b radio cassette that i need the code for the number stamped on the side is cl0272t0008784 and on the label ontop has 0008784 and also 96241482zl
Username: Regrooster
Post Number: 9864
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
